3Door Fuse Locations
Old Mar 6, 2010 | 05:21 PM
neilm's Avatar
neilm
Default 3Door Fuse Locations
Guys
The fan for my heater has stopped working, as has the cigarette lighter in my 3 door, I checked all the fuses in the fuse box but they were all fine and none of the legends on the lid referred to these items.
Is there a secondary fuse box elsewhere ?
If so... where ?
Old Mar 6, 2010 | 06:16 PM
No only one fusebox on these, some however have another single fuse holder leading away from the ignition barrel area, can't remember what that feeds though, take a ceramic fuse, ie older style, a 8amp I think white one.
Old Mar 6, 2010 | 07:00 PM
neilm's Avatar
neilm
Thank you for the response Tabetha
Hmmmm so wheres the fuses etc for the ABS ? and the little ECU that controls the centre dash panel with things like brake pad wear, washer bottle level etc ?
Old Mar 6, 2010 | 07:33 PM
Fuse for abs is behind/bottom of glovebox clipped to side of the relay.
Warning lights control is fused, can't remember which one, don't use them in mine.
Old Mar 7, 2010 | 07:20 AM
Alvyn's Avatar
Alvyn
Neil, on the 3dr the abs fuses/relays etc are located drivers side(if rhd) just above the pedals and below the dash!
Old Mar 7, 2010 | 01:19 PM
I thought they were the same as sapphy, obviously not!!
Old Mar 7, 2010 | 03:25 PM
neilm's Avatar
neilm
Cheers Guys !!
Still puzzling over the cigarette lighter fuse.
Time to get the meter out I think
Old Mar 7, 2010 | 04:32 PM
neilm's Avatar
neilm
Right after a bit of messing around with a meter the cigarette lighter is getting power so thats ok.
Its just the fan / fan switch that isnt working, so no blower, any thoughts ?
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
mjonathan24
Oct 29, 2015 10:39 PM
AJC
Oct 1, 2015 06:47 PM
Steve Escos
Oct 1, 2015 06:57 AM
