saph wont start :(
Old Mar 6, 2010 | 02:25 PM
moondust-saph's Avatar
moondust-saph
moonstone-saph
Default saph wont start :(
right i ran it out of petrol today, and after putting fuel in it wont start, it doesnot seem to prime either, kind of makes a thud noise rather than a priming sound, ive pushed the white buttin in the spare wheel well, no joy! please help
Old Mar 6, 2010 | 04:08 PM
Check fuses are ok then get to the fuel pump relay take it out and bridge 30 and 87 together, this should then run , this will tell if the pump is okay, they can be killed by debris from the tank when run low.
If this is the case reverse the current flow through the pump, it will blow all the shit back in the tank, but will work for a while, gives you time to take the tank out and clean it out.
I just use my jump starter pack with wires direct to the pump to reverse it and let it run for about 15 seconds, will do no harm at all, you willa ctually hear the crap getting spat back.
Old Mar 8, 2010 | 06:39 PM
moondust-saph
moonstone-saph
thankyou very much i will give this a go
Old Mar 8, 2010 | 06:52 PM
james kiely's Avatar
james kiely
another great tip form tabetha
DixieTheKid
Jul 23, 2023 10:16 AM
j.hammond1
30
Oct 31, 2021 05:28 PM
jdsjojo
Aug 30, 2015 07:48 PM
jdsjojo
PassionFord Swap Shop.
Aug 26, 2015 09:51 PM
