Sapphire TCA nylock nuts
Old Mar 2, 2010 | 09:26 PM
SS1's Avatar
SS1
Default Sapphire TCA nylock nuts
As above fitting new hubs,and just pondered would nylocks be a better option against the old castellated ones ???
The old ones need a refresh so any links to either would be nice
Old Mar 3, 2010 | 01:00 PM
Yes you can use nylocs for the tca joint, but it may lock on tight enough to spin the joint bit that goes through the arm, but if you apply a little pressure from a jack undeneath this will stop it spinning so the nyloc can be tightened, if this doesn't work strip some wire and cut a few strand of copper wire and put in the hole before inserting the tca joint, this will hold it tight, allowing a nyloc to be used.
Rsmat
89
Oct 12, 2015 07:50 AM
Fil
Sep 30, 2015 12:08 PM
DavidK
Sep 27, 2015 02:55 PM
Mark V8
Sep 13, 2015 09:34 AM
