1.8 zetec holds back
Ive had this problem a while now and its starting t bug me….. if I accelerate hardish like when overtaking or pulling out onto a motorway the engine gets to about ¾ throttle and holds back, if I back the throttle off a bit I can drive through it! I tried plugs/air filter leads and fuel filter a while ago but it was still there so I left it, other than this the car drives lovely does anyone have any ideas what it could be, its a 96 escort 18 118 not 130 tx in advance
Are you using BOSCH plugs ?, are your plugs leaking, corona discharge is ok but no streaking, zetecs are famous for this, due to the humidity inside the area where the plugs are.
Probably 50% of the bosch plugs I've used have leaked within the first few hundred miles, it's also possible the plug boots have slight tears on the inside where people don't use SILICONE grease on the inside of the boot where it goes over the plug, it should be used on zetecs.
fitted new plugs and icv tday and its seems to have made 100% improvement it pulls a lot better now and the cough it had about 4 grand seems to have gone, feels like a different car
thanx for all your imput people
