strange noises
Old Mar 13, 2004 | 11:21 PM
Default strange noises
Just put the engine back in my rs turbo when you turn the key the fuel pump comes on but for the first couple of seconds theres a noise like traped air could this be due to very low fuel (cars been off the road for more then 5yrs)dont know how mush fuel its got in it
Old Mar 15, 2004 | 11:42 AM
HI, if low on fuel.pump can sound strange(gurgle sort of sound)otherwise
Could be air in the system, bleed off through cold start valve union, or at metering unit head,and use fresh fuel, as old fuel can go off ,causing starting problems,careful when bleeding air off with fuel spraying about,?
normally car does'nt want to start with air in sytem, so work it out for your
self on the symtoms,
Dave,
Old Mar 16, 2004 | 06:31 PM
it was trapped air but got some bits to before i get it started cheeRS
gingeRS
17
Oct 2, 2015 09:42 AM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
rsturbo27
Sep 5, 2015 05:08 PM
