Egr removal.
Old Feb 24, 2010 | 09:31 PM
keith7981's Avatar
keith7981
Thumbs up Egr removal.
Hey,ive fit a zetec to a capri and removed all egr componants.I know this will set off the engine check light.Will this revert the ecu to a second stage with reduced performance or will it run fine as is?
Thanks
Old Feb 25, 2010 | 03:09 PM
On some but by no means all ecu's this can cause it to go into LOS, safe mode, limited operation strategy, I found this on a mondy I did, found also that keeping the exhaust gas differential pressure sensor plugged in it still worked ok, I had removed that as well initially, was dead as a dead thing performace wise, but egdps plugged back in back to normal.
Old Feb 25, 2010 | 05:26 PM
keith7981's Avatar
keith7981
Il try that.
Thank you o wise one!!!
keith
Old Feb 25, 2010 | 07:20 PM
NO probs matey, hope it works.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
CossieRich
30
Sep 8, 2015 10:08 PM
Bailes1992
Sep 3, 2015 02:17 PM
Bailes1992
Aug 16, 2015 07:14 PM
