steering twitch
Old Jan 7, 2005 | 03:38 PM
mark2's Avatar
mark2
Default steering twitch
hi all
i have a small problem with my steering on my series two when i drive the car i fill a twitch to the right in steering and i have found that if i was in third gear doing 30mph and i toggle throttel on a second and off the twitch is in syc with this and it fills like the wheel on the right is wobbling a bit , the car has had a new rack ( reconditioned)and new koni kit and i have had the car up in the air to check wheel bearings , on rotation very very smooth and the right side has left to right movement but not top and bottom movement. on the left to right movement i do notice a slight clunk from the rack and also on the left side also a slight clunk but no wobble when driving and i do have inside tyre where on right front which got tobe all this movement also i did not mention it has new full front polybushes and i did buy new tca to help me install them and that ment new outer ball joint and rollbar is fine and the tracking and do not hear any clicking from c v on full lock also when driving car straight and i wiggle steering wheel left to right and it is quite responsive so if you could helpme out i wont hold ya back
cheers
mark
tankybaby66
Feb 6, 2016 02:24 PM
IainRS1700T
Sep 25, 2015 06:44 AM
dange
Ford Mondeo Including ST
Sep 23, 2015 12:11 PM
dirtysteve
Ford Focus ST
Sep 16, 2015 05:29 AM
