Focus st 170 IMRC Fault code
Old Jan 31, 2010 | 12:39 PM
Jeff G's Avatar
Jeff G
Question Focus st 170 IMRC Fault code
Hi All any help please
Working on Focus ST170 with code P1518.(inlet IMRC stuck open)I found manifold motor control was not working so checked and replaced power transistor.
Motor now working (switch ignition on motor pulls manifold control)my problem is when you turn ignition off manifold control will not return fully.
Manifold control with cable disconnected moves freely but dose
not appear to have any spring attached.Can anyone confirm there is a spring and if so where it should be or is it returned (pushed back) by motor and cable.
Thanks Jeff
NC53
Sep 13, 2015 03:05 PM
Si B
Sep 12, 2015 06:49 AM
focus2351
Sep 9, 2015 09:33 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
