Boost or not to Boost?
Old Jan 30, 2010 | 08:45 PM
4x4 S2 Cossie's Avatar
4x4 S2 Cossie
Question Boost or not to Boost?
Hiya,
Wondered if anyone could answer my query?.....
Bought a 4wd sierra cossie earlier this month; stage 3, MSD 380+ chip to run with Siemens 55lb's and stg3 T34.....
It hadn't been set-up so took it to a local garage. Basically they fitted a manual boost controller to adjust the boost but shoudn't the remapped chip automatically run approx. 30psi boost through the amal? Before they installed the manual boost controller it peaked at approx. only 1bar?
Any ideas why this would be?
CheerRS,
Chris
Old Jan 30, 2010 | 11:09 PM
martysmartie's Avatar
martysmartie
Most likely the amal was faulty, so they replaced with a bleed valve, as you say the chip will control the Amal for the boost only thing needs changing/modifiying is the jet in the (R) sector of Amal.
Martin
Old Jan 31, 2010 | 11:19 AM
The only thing that needs changing is your garage.
Take off the bleed valve, fix the std set up with a working amal, it's far better and certainly safer.
Old Jan 31, 2010 | 11:39 AM
4x4 S2 Cossie
Cheers guy's! Bleed valve coming off!! Thought it seemed strange!!
Will a standard amal do the trick or how do you modify?
CheeRS, Chris
Old Jan 31, 2010 | 03:29 PM
4x4 S2 Cossie
Does anybody know how to adjust the standard amal valve to suit 30psi as programmed into the mapped ECU? Pipes R and C have restrictor inserts whilst pipe W has nothing in mine.
Also thinking about upgrading to a -34 actuator - would this be the best one to go for?
CheeRS, Chris
Old Jan 31, 2010 | 06:37 PM
martysmartie
You would need a -31 or -34, -31 is normally suffice, it's hard to say specific instructions as some just remove the jets some drill/use bigger to get desired boost. But you need to make sure you get it right otherwise could run to much boost. Easiest way to think if you wanted to run 15PSI and you have a actuator than can handle 10PSI then 5PSI would need bleeding off to achieve.
Martin
Old Feb 1, 2010 | 05:26 PM
4x4 S2 Cossie
Thanks Martin
Chris
Old Feb 1, 2010 | 06:39 PM
Just take the restrictors out, ecu should control boost.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
