escort 7/8 turbo diesel problem
Old Jan 25, 2010 | 08:11 PM
tim2008's Avatar
tim2008
Default escort 7/8 turbo diesel problem
can any body tell me how many revs it would take to make a diesel turbo actuator move while the car is stationary.i rev it 3,4,5000 revs and it dont really move.theres no oil leaks and theres no play in the turbo blades etc.i used a bike pump to make the actuator work (which it did) so thats ok.if i take the pipe of the actuator there is some pressure coming from the compressor.im getting no were quick lol.thank's
Old Jan 25, 2010 | 08:38 PM
forevaford's Avatar
forevaford
i dought it will even move stationary. needs load on the engine. fit a boost guage
Old Jan 25, 2010 | 08:50 PM
jghs83's Avatar
jghs83
can you smell purple?
From: normally dewsbury west yorkshire, but i could wake up anywhere!
as forevaford said get a boost gauge, t-piece this into the actuator pipe.
what exactley is the problem?
Old Jan 25, 2010 | 09:47 PM
tim2008's Avatar
tim2008
Unhappy still no good,i will get a boost gauge
when i got the car and put my foot down a little,it cut out with a lot of black smoke.got in home and found that the rubber bend from the filter to the air intake had caved in (air filter was very old).changed the filter and it was ok for about 2days.now its just really slow.the turbo is spinning but something isnt right.someone menioned a airmass sensor (i think that what he called it).i even put a new diesel filter on but no diffrents.when your driving it,it feels like something is holding it back.
Old Jan 25, 2010 | 10:05 PM
jghs83's Avatar
jghs83
exactley the same problem with me van, its the intake. i cut mine down half way and repalced it with a silicone elbow and stainless bend, its a hell of a lot better.
ill try and get pics.
failing that. used a compressor air line, take off the diesel cap and blow down both fuel lines and re-bleed. could be be crap in the tank/pipes.
let me know how you get on.
Vincereese
Jun 1, 2023 09:14 AM
3i Jim
Nov 20, 2015 05:12 AM
muz
Aug 16, 2015 12:57 PM
druidgetafix
Aug 15, 2015 10:22 AM
adriansaleem
Aug 1, 2015 09:28 PM
