xr4x4 24v cosworth conversion help needed
Old Jan 24, 2010 | 03:01 PM
bad boy racer's Avatar
bad boy racer
Unhappy xr4x4 24v cosworth conversion help needed
hi all need a bit of help with the wireing side of the 24v cosworth conversion on my sierra.
the car is the 2lt xr4x4 model.
i belive the loom and ecu from the granada 24v is in and just needs wireing in is there any wireing diagrams out there that could help or has any1 done this converison that could give some pointers.
thanks
Old Jan 24, 2010 | 07:15 PM
Never done this particular conversion, but ther eis very few wires to connect engine loom into car loom.
Just the following should get you somewhere permanent live(red, or red/blue), switched live(black), earth(brown), fuel pump output, may be black/red, but will be black/colour, then thin green tacho, brown/white temp gauge.
The ecu loom normally has a plug near the main ecu conenctor where it plugs into the car loom to get these wires hooked up, it will normally be 5 or 6 wire connector, and on sierra at base of windscreen area(inside car) tucked up behind the main loom wher eit is secured to the bulkhead with the plastic clips.
Old Jan 28, 2010 | 04:33 PM
bad boy racer
Talking
thanks for getting back to me will pass this on to the chap thats looking at it 4 me
many thanks
Old Jan 28, 2010 | 10:13 PM
2ndGear's Avatar
2ndGear
try this site has lots of info
http://www.maddoldbugger.supanet.com/
mk22door
49
Mar 26, 2022 07:15 AM
Aug 14, 2015 07:29 AM
col93saphcos
Aug 7, 2015 03:21 PM
