xr3i (efi) fuelling problem
Old Mar 11, 2004 | 04:17 PM
Default xr3i (efi) fuelling problem
my xr3i hiccuped & stopped recently, would turn over but not run... not enough fuel.
replaced pump & tank (it had a small crack) with new parts.
it still won't run
gonna check for blockages & blow out the pipes.
Any other cause for this ? ECU , relay etc.
i HATE walking in the rain
Cheers all
signed (appropriately)
damncar
Old Mar 11, 2004 | 07:54 PM
HI,
Why did u change the pump was it a guess,Can u hear the pump run, or running,
if not check at the pump power connection, there is power 12volts approx,
if not check fuse's, and relays, and for a break in the wiring, if pump is running
check fuel is getting past fuel filter,
Dave,
Old Mar 14, 2004 | 03:36 PM
turned out the non o/e pump wiring was reverse to the original ford pump 'tho the connexion was the same , so the pump was operating in reverse....ouch! should have it back soon
thanx 4 the reply David
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
dms04
Sep 11, 2015 01:57 PM
