saph rev counter
Old Jan 22, 2010 | 07:50 AM
whittyscossy's Avatar
whittyscossy
Default saph rev counter
I have heard different ways to get the rev counter to work correctly after a coil pack conversion , what is the best way?
i.e mk 1 mondeo counter
re-wire
etc
Car is a 89 2wd saph running l8 ecu ( don't know if that matters)
Whitty
Old Jan 22, 2010 | 08:13 AM
rog's Avatar
rog
Personally i'd rewire it, but i think you can get some rare late model of saphs that came with coilpack so you might be able to get a counter out of there.
Old Jan 22, 2010 | 08:22 AM
JTECH James's Avatar
JTECH James
Passion for Fords!
the clock mod is best on the 4x4 saffs and works fine, so you may need to get 4x4 clocks, or do the diode pack mod
Old Jan 22, 2010 | 07:29 PM
I just use a tacho driver (£30) works perfect.
Rsmat
89
Oct 12, 2015 07:50 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
landaqmabba
Sep 15, 2015 07:16 PM
