Fiesta MK3 Problem...
Old Jan 20, 2010 | 10:08 AM
Lewis-_-92's Avatar
Lewis-_-92
Default Fiesta MK3 Problem...
i recently brought a mk3 fiesta 1.1 as my first car. it was stood around for 3 years rotting away before i brought in but iv got it now and fixed it up its just this minor problem i cant fix.
when i accelarate the revs die down and then shoot up again and loads of white smoke comes out the exhaust any solutions?
i mixed some redx engine cleaner how long does this take to do its job?
Old Jan 20, 2010 | 12:41 PM
Can't even remember are these carb or efi ?
Old Jan 20, 2010 | 12:55 PM
martysmartie's Avatar
martysmartie
Pretty sure it would be carb, if not CFI, if carb you could try spraying some easy start or a substitute into the venturi the white "Smoke" is probably just condensation. Have you checked the ignition system is good I.E replaced plugs, leads, rotor arm.
Martin
Old Jan 21, 2010 | 08:54 PM
Lewis-_-92's Avatar
Lewis-_-92
Martin
Ye they are carbs. iv changed the plugs and the leads look fine like new still and i also applied some redx engine cleaner it seemed to have made it a little better. it seems to only do it when its cold its got an automatic choke so im guessing the choke is sticking or broke, how can i tell?
Old Jan 21, 2010 | 08:55 PM
Lewis-_-92's Avatar
Lewis-_-92
Carbs mate i think the rs turbo is efi.
Old Jan 21, 2010 | 09:15 PM
AndyST's Avatar
AndyST
What year is this? Mk 3 Fiesta went to CFi in 1994. If it's still got 3-year old petrol in I'd bin it and try some fresh.
Old Jan 21, 2010 | 10:18 PM
Lewis-_-92's Avatar
Lewis-_-92
N reg soo 95 isnt it?
ye i thought that but i cant cifien it out so i just thought run it till the tank is empty, just another quarter of a tank to go lol.
mk3ste
Oct 17, 2021 10:09 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
