yb engine
Old Jan 15, 2010 | 02:32 PM
stevemc's Avatar
stevemc
Default yb engine
Need some help, cosworth yb engine using a lot of oil,no leaks ,and its not smoking from exhaust,anybody any idea what to check out etc.
thanks steve.
Old Jan 15, 2010 | 03:01 PM
Billy_RS's Avatar
Billy_RS
Head gasket?
Old Jan 15, 2010 | 03:17 PM
TurboOsmond's Avatar
TurboOsmond
check the inside of the header tank for milky / scummy residue , if so might be the head gasket , if not could be valve stem oil seals or piston ring-s gone
piston rings can be checked with a comression tester on each cylinder, quite easly done but means a rebuild if there gone
and valve stem oil seals can be checked by whiping the cam cover off , if there still soft n maluable then there fine if there hard n brittel then they idealy need changeing and normaly means a head rebuild
some one else must have another few ideas
Old Jan 15, 2010 | 03:19 PM
D16PJM's Avatar
D16PJM
im not great with these engines but wouldnt the valve stem seals smoke on start up and piston rings smoke when driving and he has no smoke.
Old Jan 15, 2010 | 03:20 PM
The DIVA's Avatar
The DIVA
What grade oil you using ?
If you use 5w 40 or 0w 40 it will drink it....if you are try using the proper grade (10w 40) and it should be a lot better.....
they use oil for fun anyway, and all depends how hard you use it
Old Jan 15, 2010 | 03:24 PM
BigErn's Avatar
BigErn
How much do you consider "a lot" of oil?? Mine demolishes the stuff but I dont care as long as it still goes like fook
Old Jan 15, 2010 | 05:13 PM
stevemc's Avatar
stevemc
Default yb cosworth
cheers lads,using 10/40 magnatec.
Old Jan 15, 2010 | 05:17 PM
v man's Avatar
v man
Zee Germans are coming
if it uses a lot of oil then just think of it that it always has good clean oil he he he
just change the filter and you have on the go servicing
Old Jan 15, 2010 | 05:24 PM
cossiejay's Avatar
cossiejay
has the turbo blown the seals
Old Jan 15, 2010 | 05:27 PM
James Porter's Avatar
James Porter
Shit oil IMO anyway mate
Old Jan 15, 2010 | 05:31 PM
stevemc's Avatar
stevemc
Default yb cosworth
No the turbo is ok ,its been checked out,what would be the average oil useage on say 500 mile normal running?
Old Jan 15, 2010 | 05:34 PM
nugnah's Avatar
nugnah
mine use about 1litre / 1000km
jason
Old Jan 15, 2010 | 06:00 PM
cossyking's Avatar
cossyking
jason
both of mine use non and 1 is 540bhp
Old Jan 15, 2010 | 06:04 PM
MarkN's Avatar
MarkN
The handbook says you can use up to 1 litre every 600 miles or so. Mine doesn't use that much - but it certainly needs a good top up every 1000 miles. It always has done and has never got any worse - it doesn't smoke at all so fook knows where it goes...
Old Jan 15, 2010 | 06:12 PM
Toe Knee's Avatar
Toe Knee
have u tried using different oil mate?! as said i wouldnt use magnatec either i run mobil1 15/50 in mine!
Old Jan 15, 2010 | 07:05 PM
Alvyn's Avatar
Alvyn
The YB engine has always been known to use a bit of oil in most cases and it had alot to do with what grade you used and also how hard you drove it!(Ford's from new put a sticker inside petrol cap saying check oil daily)
Old Jan 16, 2010 | 10:16 PM
martysmartie's Avatar
martysmartie
If it was burning you would be seeing smoke, when new Ford said the engine can consume upto 1.0 litre of oil every 600 miles, they always have been known for a appetite for oil. Expect the above figure to be higher now as thats when new. They do not suffer badly from stem seals, you can see though if you start up from cold you will see a blue smoke where the oil has got past into the cylinder also on overrun and then acclerating will show same thing.
Martin
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
