map sensor
Old Jan 14, 2010 | 11:03 PM
raycov's Avatar
raycov
Default map sensor
how can you check weather a 3 bar map sensor is working correctley
cheers
Old Jan 14, 2010 | 11:07 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
its a pressure to voltage calibration.
you need to apply a measured pressure to the reference feed, and measure the output voltage against the manufacturers tech data
Old Jan 14, 2010 | 11:23 PM
raycov's Avatar
raycov
hello james
it ray from coventry i talked to you the other day,the car still wont start ,or when it does fire it cuts out,thinking the map sensor might be iffy
cheers
Old Jan 15, 2010 | 07:09 AM
oldford's Avatar
oldford
Measure voltage on map sensor signal with engine off, ignition on. Should be around 1.5 Volt.
Old Jan 16, 2010 | 10:05 PM
martysmartie's Avatar
martysmartie
When it does start does it check out loads of black smoke? If it does this is an indication of overfueling which can be caused by the MAP, have you checked the hose?
Martin
Old Jan 17, 2010 | 10:12 AM
As said just measure, when duff they tend to go mega rich/high signal reading, or stop reading altogether.
They are just a simple wheatstone bridge affair, with a voltage scan of 250mV(0.25V) to 4750 mV(4.75V).
The scale is 15.46mV per Kilopascal, if you want to work out exactly.
The 2 bar is 22.61mV per kilopascal.
Each has 17 different steps/outputs.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 25, 2015 01:38 AM
