Sapphire ABS blink codes
Old Jan 14, 2010 | 04:02 PM
Daddyn's Avatar
Daddyn
Default Sapphire ABS blink codes
Is it possible to do blink code tests on a 2wd Sapphire ABS ecu. If so could anyone tell me which pins and codes or where to find them so I don't have to spend ages trawling through crap to try and find out. Thanks to all you genius's.
Old Jan 14, 2010 | 04:13 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
easiest thing to do is test the resistence of the ABS censors, normally the fault!
Old Jan 14, 2010 | 05:07 PM
Daddyn's Avatar
Daddyn
Done that mate. O/S/F had slightly higher resistance (still within tolerance) changed it but still no good. Light comes on with ignition and never goes out so if ecu is readable should give me fault straight away!
Old Jan 14, 2010 | 05:13 PM
orion_crazy_carl
orion=mini saff
is the abs pump making a noise?wiring ok to it?not sure if it can be read, but they are a pain lol
Old Jan 14, 2010 | 06:29 PM
Daddyn's Avatar
Daddyn
Cheers. Pump is making pressure but I don't know how much. Did look at it and wonder which is pressure switch but obviously i would be clutching at straws. If u know anything about pump and if it's a simple make/break pressure switch that I could link out to try, let me know and i'll give it a go. Thanks for reply's.
Old Jan 14, 2010 | 07:53 PM
jon@work's Avatar
jon@work
Check your brake fluid level. If it looks OK, take the 2 pin connector off the brake fluid reservoir and bridge the 2 terminals together with a short bit of wire. If the light goes out, you need a new reservoir cap.
tankybaby66
Feb 6, 2016 02:24 PM
muzzman1
Sep 30, 2015 08:59 PM
