Car keeps cutting out.
Old Jan 11, 2010 | 05:23 PM
S1 Replica 1.3's Avatar
S1 Replica 1.3
Default Car keeps cutting out.
hi, i have a mk3 escort 1.3 that keeps cutting out so far ive replaced the coil and dizzy , but the problem still persists
any help would be apprceiated
Old Jan 11, 2010 | 07:21 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
soudns like a carb problem, check the anti-dieselling solenoid on the carb (the bit with a wire going to it)
they tend to bung up or just fail and cause the mix to lean way too much, if you hold about 2krpm+ it doesn't cut out though, if this is the case, then check that valve out.
you can , to test, remove it and then pull the end bit and spring off the valve and replace without the parts, race cars did this due to the potential failure.
Old Jan 11, 2010 | 07:47 PM
It is more likely to be a carb problem, you need to describe in more detail, does it run rough before it cuts out, does it do it at any particular time, eg hot or cold, does it start up again no bother, does it idle ok, may just be a lean mixture especially as the weather is so cold, could be the idle speed is to low.
Don't go just replacing stuff though, always do the cheapest adjustments/checks first.
Fordmad!
Sep 26, 2015 05:24 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
155lee
Aug 14, 2015 11:21 AM
track.focus'd
Aug 12, 2015 05:53 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
