engine smoke or turbo smoke ?
Old Jan 11, 2010 | 04:34 PM
wally rs's Avatar
wally rs
Default engine smoke or turbo smoke ?
hi guys ive got big turbo escort coz the heads been rebuilt, new bottom end 1 new piston with new rings, engine was rebuilt 12,000 miles ago,when running down hills with no throttle it smokes ?
Old Jan 11, 2010 | 07:53 PM
How many miles has the turbo done ?, there is no seal on the turbo in the conventional sense and these do suck a certain amount of oil past on overun, not enough to notice unless quite worn though, check for play in the shaft, will have a little in/out wiggle, but shouldn't be able to detect any up down movement.
If you need a turbo overhaul I can recommend Turbocentre 01924 404112, get a step gap seal and 360 bearing done at same time.
Old Jan 11, 2010 | 09:25 PM
wally rs's Avatar
wally rs
thanks will check for movement 2moro
RUBY123
Oct 22, 2023 12:04 PM
Michael Wisbey
Aug 14, 2015 11:57 PM
