what cable to starter motor
Old Jan 11, 2010 | 12:04 PM
simps's Avatar
simps
Default what cable to starter motor
im about to rewire my engine over the next fortnight ive got a new engine loom but i need to replace a few other tings too.
what type of cable would you recommend for use from my battery terminal to the starter motor and alternator? as i want to replace these. and put new terminals on the battery.
the engine is a 1.8 xr2i if it makes any difference
Old Jan 11, 2010 | 12:12 PM
cossiejay's Avatar
cossiejay
thick ones
Old Jan 11, 2010 | 02:00 PM
simps's Avatar
simps
tell me somethin i dont know lol.
i was after a rating or a place to contact for them.
what is the best diameters?
Old Jan 11, 2010 | 02:15 PM
jon@work's Avatar
jon@work
I'd use 25mm^2 (rated at 170amps) for the starter.
Depending at what your alternator is rated at, I'd probably use 16mm^2 (rated at 110 amps).
Old Jan 11, 2010 | 03:03 PM
simps's Avatar
simps
thanks for the help mate any idea where i would buy this stuff or would a local hardware store have it in?
Old Jan 11, 2010 | 03:22 PM
jon@work's Avatar
jon@work
www.polevolt.co.uk
Old Jan 11, 2010 | 03:50 PM
Could also use vehiclewiringproducts.co.uk
these tend to be good for smaller orders.
Old Jan 11, 2010 | 06:30 PM
simps's Avatar
simps
ok cheers will check them out too.
gotta order a few things so will see which one works out cheaper.
bobsworth
77
Mar 24, 2016 09:30 PM
A.t.p
Oct 23, 2015 07:54 PM
cossie362
Oct 11, 2015 03:53 PM
muz
Sep 30, 2015 08:29 AM
marky_g
Sep 12, 2015 04:26 PM
