Wiper Issue
Old Jan 9, 2010 | 07:47 PM
indy2010's Avatar
indy2010
Default Wiper Issue
Hey Guys,
I was wondering if you could help. my driver side wiper on my 95 escort isnt working anymore since the snow started and the passenger one works fine. Is there anything i can try before taking it for a new motor ie tighten the wiper arm, fuses etc.
Old Jan 10, 2010 | 06:59 PM
See if the linkage has popped off, under the scuttle panel, you will see the linkage off if it has, otherwise they will be conencted as they should be to the wiper motor area linkage.
If that is on remove the arm not working and ensure the shaft the wiper goes on is turning back and forth as it should, if it is, it may have stripped the centre of the arm threads, all is not lost however, the spindle will be ok as the armis the softer part so goes first, so put some strands of wire through the hole through which the spindle goes when fitted and force on the spindle, then tighten down as usual with the 10mm nut, this works as it makes a very tight joint.
No doubt caused by the recent snow ice etc, just use the straight edge of the ice scraper to push on the blade along it's length before switching them on will stop it happening again, also useful pressing in the door seal rubber to break ice seal whenthey are jammed shut.
Mark_
14
Jan 16, 2016 05:27 PM
stevecfrst1
Sep 30, 2015 05:18 AM
SMILER258
Sep 28, 2015 09:04 AM
turbotrev
14
Sep 27, 2015 10:44 AM
pabloXR
Sep 21, 2015 12:42 PM
