hit the verge! now doesnt go properly!!!
Old Jan 9, 2010 | 05:56 PM
gareth01544's Avatar
gareth01544
Default hit the verge! now doesnt go properly!!!
i hit the verge in the ice on Christmas day. it ripped off the front bumper on my rs seirra cosworth and punctured the radiator. i have got the new rad on now and filled with water. fitted the complete radiator, intercooler and fans.
Went to take it to the body shop today to have the new bumper spayed and fitted and have the stone chips in the bonnet sprayed. when i put my foot down it went the cut out for a couple of seconds the came back to life and went for a couple of seconds then cut out for 4 or 5 seconds again!!!!!!!!
any help please?
or even no what it could be ?
cheers gareth
Old Jan 9, 2010 | 06:00 PM
graham c's Avatar
graham c
check crank sencor as its rite behind the rads and the wire hands down?
Old Jan 9, 2010 | 06:01 PM
Adam.'s Avatar
Adam.
Needs Beer Tokens.....
did u fill it with water only? hope its not something to do with your water tank/pipes being frozen mate
Old Jan 9, 2010 | 06:07 PM
Toe Knee's Avatar
Toe Knee
also check the crank pulley for damage as i damaged mine the other week!!
As said, hope u used antifreeze and not just water to fill it.....
Old Jan 9, 2010 | 06:09 PM
gareth01544
no plenty of anti freeze in cheers
Old Jan 9, 2010 | 06:10 PM
gareth01544
does it break the crank shaft sensor?
Old Jan 9, 2010 | 11:27 PM
supertouring230's Avatar
supertouring230
intercooler pipe split or not on proper ???
Old Jan 9, 2010 | 11:34 PM
gareth01544
Originally Posted by supertouring230
intercooler
No all pipes are good and fitted correct. The actual engine cuts out got 3-4 seconds when acelerating then comes back to life for a 1-2 seconds then cuts out again and so on !!!!
Old Jan 10, 2010 | 06:52 PM
Do the wiggle test on the crank sensor connector, see if it makes it stutter ?
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Chas
Oct 5, 2015 07:13 PM
ajamesc
Sep 8, 2015 06:51 PM
