any1 help settle a lil argument???
Old Jan 7, 2010 | 03:01 PM
fezzaturbs's Avatar
fezzaturbs
Red face any1 help settle a lil argument???
hi troops, basically, im runnin a frst with beige 701, -31actuator, t3 turb, uprated fuel pump, uprated oil pump, pace alloy intercooler, full stainless exhaust n a KnN. im sayin to my m8 i need a chip calibrated now to run it all n he's sayin i dont.. whos rite coz with just them mods i mentioned, theres not much difference if any. many thanks guys
Old Jan 7, 2010 | 03:06 PM
fiend's Avatar
fiend
If you don't have a chip then you won't be able to turn the boost up above 10psi, as the overboost protection will keep cutting in.
So you need a 195 chip to get the best out of those modifications.
Old Jan 7, 2010 | 03:22 PM
fezzaturbs's Avatar
fezzaturbs
Smile
wats 10psi in bar coz i can hit 1.2 bar but soon as i hit 1.2 bar in 3rd or above it trips n limits me ta 0.5 bar. if i try exceedin 0.5 after its tripped i kangaroo??? also for a lil experiment, i turned my boost down so it didnt trip.... n it wouldnt fuel me enough once i got over 128 mph??? is that down to the chip 2?? many thanks
Old Jan 7, 2010 | 03:58 PM
cozmeister's Avatar
cozmeister
More boost Igor!
10psi = 0.78 bar. 14.5 psi = 1 bar.
The chip will try to cut the boost if there's more than it's designed to allow, as long as there's a boost controller of some sort (ie, the amal valve) connected.
Old Jan 7, 2010 | 04:04 PM
fezzaturbs's Avatar
fezzaturbs
i bought her n she had a bleed valve. i removed this couple of weeks ago n fitted a amal valve of a s2. since this i struggle to boost past 0.4??? is amal valve fooooked??
Old Jan 7, 2010 | 04:57 PM
cozmeister's Avatar
cozmeister
More boost Igor!
It might well be. Switch on the ignition (don't start the engine) and disconnect and re-attach the plug on the amal valve a few times - it should click quite loudly if it works. You did the right thing dumping the pikey bleed valve.
The default behaviour is to protect the engine, so you will only get about 5psi, if that.
Old Jan 8, 2010 | 08:14 PM
With any mods like this I would get a fuelling check done on the rollers could be money well spent, if it saves your engine.
Old Jan 8, 2010 | 08:45 PM
fezzaturbs's Avatar
fezzaturbs
hi pal, im gonna try wat u said over the wkend. ive just orded a evolution chip for my spec too =) back to the amal valve, im not sure til i check but when my m8 1st fitted amal valve, he ran a live straight too it, n it clicked loud ish on ignition bein turned. i mentioned to wire it up where it should be ( old amal valve wires) so he did. he checked them 1st too see if they were good and they was. but i dont hear a click no more like i used too when it had direct live??
Old Jan 11, 2010 | 11:40 AM
cozmeister's Avatar
cozmeister
More boost Igor!
The amal valve has a live feed (On a Cossie this comes from the fuel pump relay), and the ECU switches the earth. Check that there's continuity for the feed and the earth - it might be shorting somewhere.
bigryrs
Mar 28, 2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
pabloXR
Sep 21, 2015 12:42 PM
B19-TRB
Jun 30, 2004 03:45 PM
B19-TRB
Jun 30, 2004 12:13 PM
