Is it ok if,
Old Jan 5, 2010 | 11:26 AM
Steve the Plumber's Avatar
Steve the Plumber
The original Rouge Trader
Default Is it ok if,
Now ive got your attention,
Is it ok if i was to drill and tap the radiator end cap( just above the rad switch) and fit the an external water temp gauge sender?
The rad is a Airtec Alloy one.
Ta.
Old Jan 5, 2010 | 02:19 PM
jon@work's Avatar
jon@work
I doubt the material would be thick enough for you to cut a thread. You'll probably have to have a threaded boss welded on.
Old Jan 6, 2010 | 11:35 AM
What he ^^^ said, but you could also consider putting it somewhere else, like in the stat housing plenty thick enough there.
Old Jan 6, 2010 | 12:17 PM
1cosworth's Avatar
1cosworth
on mime i ve drilled the swirl pot and welded a bolt for the sender to screw on
