cosworth fault
Old Jan 1, 2010 | 07:46 PM
carlos1395's Avatar
carlos1395
Default cosworth fault
why when i connect and disconnect my phase sensor plug the fuel line pressures up have i got a wiring plug on wrong .does the brown plug on the engine loom go on to the brown sensor on the side of the inlet manifold
Old Jan 1, 2010 | 08:02 PM
Toe Knee's Avatar
Toe Knee
yes mate all the sensors are colour coded, the brown goes onto the inlet, blue the water temp on the back of the head, dizzy is the black one, CPS goes to the white one etc etc.
Does the car not run or something?!
Old Jan 1, 2010 | 08:19 PM
carlos1395's Avatar
carlos1395
hi bud no it doesnt run ive just built the car from a trimmed shell but when im cranking the car it puts fuel straight through in to the turbo and i mean a lot
Old Jan 1, 2010 | 08:55 PM
Toe Knee's Avatar
Toe Knee
bit confused mate, fuel cant get into the turbo?! do u mean fuel straight thru into the cylinders?!
Old Jan 2, 2010 | 09:33 AM
carlos1395's Avatar
carlos1395
yes mate its going straight through the cylinders and in to the turbo .
its got today to start if not its on the bay tonight
Old Jan 2, 2010 | 11:23 AM
Fuel can indeed go through to the turbo, and seep out the joins between the trousers and the turbo etc.
Check number 2 injector lead, by taking off and see if this cures it ?
If it does, did you or anyone else do any reapairs to the loom ?
I've only seen it once before, but when someone was taping up a ropey loom, they misplaced the iscv plug with the no2 injector plug, as they are the same length in the loom.
This resulted in the no 2 injector being pulsed continuously by the ecu thinking it was the iscv, which is pulsed continuously!!
Old Jan 2, 2010 | 06:05 PM
carlos1395's Avatar
carlos1395
thanks bud il check that ive just the loom from north yorkshire breakers so il have look
JK12
33
Apr 26, 2021 12:09 PM
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
Aug 14, 2015 07:29 AM
