new engine cuts out when it gets hot
Old Dec 27, 2009 | 02:12 AM
RS Classics's Avatar
RS Classics
Default new engine cuts out when it gets hot
hi ther this is my first post. me and my dad have just put in a brand new cosworth engine into a sapphire and i was running it in on a trip away and when i stopped for lunch it cut out on me and it would not start for a while then i had lunch then whent to start it and it went second go. then it went for 7 or so minutes then it cut out. it seems to be when it is hot it cuts out. my dad thinks that it may be a sensor ( crank mabey) and i was wondering if any of you guys know what the problem could be. we are away atm so we havent had the chance to have a good look at it.
Old Dec 27, 2009 | 02:21 AM
RS Classics
Old Dec 27, 2009 | 07:32 AM
RS500/364's Avatar
RS500/364
I would always say on this the Phase sensor !
Old Dec 27, 2009 | 12:21 PM
As above the phase sensor, or more specifically it's wiring, look to see if the wiring is all cracked and broken off, the earlier sensors had shit wire insultion, later ones with red/blue wires were/are ok.
Also have a wiggle of the crank position connector, the connector loses it's grip, and this can cause all amnner of odd problems like this, almost defo lecky in nature.
How old is the fuel pump ?, have you rewired it, needs the fuel pump and fan rewire if you want to keep the engine healthy, as a minimum.
Old Dec 27, 2009 | 01:00 PM
BigErn's Avatar
BigErn
As above really, check phase sensor and crank sensor. is the wiring to both ok and are they both new sensors and gapped correctly?
Old Dec 27, 2009 | 08:12 PM
RS Classics
yea we have all new sensors at home so will check and swap when i get home and will see if that works. thanks for that guys.
Adam-M
Aug 26, 2015 05:53 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Bailes1992
Aug 16, 2015 07:14 PM
track.focus'd
Aug 12, 2015 05:53 PM
