sierra cos. oil lamp
Old 22-12-2009, 11:21 AM
1cosworth
1cosworth's Avatar
Default sierra cos. oil lamp
what could be the problem its got oil for sure
Old 22-12-2009, 11:28 AM
TurboShed
Cossiemodo
TurboShed's Avatar
The light is on all the time? Some of the time? You have oil pressure??
Old 22-12-2009, 11:35 AM
1cosworth
1cosworth's Avatar
it came on this morning and still is on i was trembling at the begining but now is constantly on.the oil pressure gauge gives me some figuers but its a cheap one.dont know if i can trust it
Old 22-12-2009, 12:18 PM
martysmartie
martysmartie's Avatar
Most likely sender faulty failing that will be shorting to earth from dash to sender somewhere most likely where goes through bulkhead this is assuming your oil circulation is ok which I suspect it will be.
Martin
Old 22-12-2009, 12:25 PM
1cosworth
1cosworth's Avatar
i ll change the sender tomorow and see what happens. by the way do you know if the sender is the same as the one used in 2lt sierra
Old 22-12-2009, 12:28 PM
martysmartie
First just disconnect the wire off the sender, light I am sure will extinguish if stays on is getting earth from elsewhere. Pretty sure sender is same as Pinto.
Martin
Old 22-12-2009, 12:46 PM
1cosworth
1cosworth's Avatar
thanks alot people
Old 22-12-2009, 01:05 PM
COLEYST200
COLEYST200's Avatar
wot is it saying the psi is
Old 22-12-2009, 05:50 PM
So long as it fits the senders are all a very similar pressure anyway so will be fine, and most 1/8 NPT.
As said though most likely the sender, just be aware they are not unknown for doing this shortly before falling to bits and the plastic part breaks letting all the oil out!!
Old 22-12-2009, 08:33 PM
1cosworth
1cosworth's Avatar
i just came back from the garage the cable atached to the sender snaped it was easy to find out what had happend ,but that was it cosworth engine bay as always was a no can put hand in.goodnight everybody and thanks again
mike elsome
14-09-2015 04:08 PM
yorkie92
06-09-2015 05:34 PM
Adam Graham
06-09-2015 06:04 AM
hopper350
04-09-2015 12:53 AM
Quick Reply: sierra cos. oil lamp
