ford focus traction control
Old Dec 21, 2009 | 06:11 PM
wraith1966's Avatar
wraith1966
Default ford focus traction control
merry christmas everyone
sometime ago i got some very good help from here.just wonding if someone can help again..right i have a 2008 ford focus 17.53cc tdci "new shape" it has abs and esp, is there away of turning off the esp "tracion control" as there is no switch i can find inside the car ! it says in the manual switches should be next to the heated windows etc but no there is no switch..just the 2 for the front and rear heated windows, i need to turn it off its crap in the snow
hope i can get some good news on this
Old Dec 21, 2009 | 06:36 PM
wraith1966's Avatar
wraith1966
just posting i have found out from someone else, where the switch is.its on the display between the clocks which you have to use the stick on the left side of streering wheel. goto menus and press set scroll down to ESP and press set. yellow esp light will come on to confirm the tracion control is switched off.. this is resetted every time the car is switched off !!! and you must then do it over again to switch it back off
hope this helps someone else out...
taylora1409
Aug 12, 2015 12:06 PM
