crank sensor saph 4x4
Old Dec 18, 2009 | 06:45 PM
jayjay's Avatar
jayjay
Unhappy crank sensor saph 4x4
is ther two sorts ie length changed the sump on mine and now the sensor it to long and is hitting the pully or have i lost a spacer help please
Old Dec 19, 2009 | 01:49 PM
The sensor bracket is adjustable as the holes that secure it are elongated, so that it can be set between 0.6mm and 1.0mm in between the lug and pulley teeth, obviously the sump gasket you used was slightly thinner so the sump, and sensor are closer to the pulley now.
Old Dec 20, 2009 | 04:54 PM
jayjay's Avatar
jayjay
its about 20mm to long dont think it will adjust that much wot about pullys are ther two sorts?
Old Dec 29, 2009 | 07:42 PM
jayjay's Avatar
jayjay
any one help pleas
Old Dec 29, 2009 | 07:52 PM
fatmike's Avatar
fatmike
It shouldn't of changed it mate unless you are running a different type of sump??? If you are you will have to ask the dealer you got the sump from because the measurements shouldn't be that far out. The only difference in pulleys are between the 4x4 late spec, and the older/2wd ones. However there is no difference in size, just on what pulley system they run. (Late spec 4x4s run single aux belt, and others are twin belt systems).
Dr. Ickxs
Sep 15, 2015 10:15 PM
mike elsome
Sep 14, 2015 04:08 PM
Si B
Sep 12, 2015 06:49 AM
truffleshuffle
Sep 10, 2015 09:35 PM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
