Fitting 2wd flyweel
Old Dec 13, 2009 | 08:44 PM
kaisersolsay's Avatar
kaisersolsay
Default Fitting 2wd flyweel
Hi,
Has my fly lightened and balanced and now refitting. I didnt mark its position when I took it off.....any advice on how it should line up relative to the crank?
Old Dec 13, 2009 | 09:00 PM
jon@work's Avatar
jon@work
the 9 holes aren't equally spaced - it'll only fit one way
Old Dec 14, 2009 | 03:06 PM
Might be a good idea to upgrade to the ARP bolts at same time ?
Did you slot your flywheel, or just remove metal from the ring ?
What weight did it save ?
Sorry I'm just a nosey git, mine went from 8.9KG to 6.6KG from removing a lot of the ring, no slotting.
Oct 9, 2015 07:38 PM
MARKYMARKONE
Aug 20, 2015 12:55 PM
markk
18
Aug 17, 2015 05:19 AM
155lee
Aug 14, 2015 11:21 AM
lockie
Jul 31, 2015 10:03 PM
