Saph fuel tank removal
Need help disconecting the filler pipe from the tank. I've disconected the fuel pump pipe and unbolted the retaining bolts and strap but the tank is now hanging from the filler pipe. Cant see how it disconnects. Can anyone help? Cheers.
As said there is a screw or two securing the filler pipe to the body where the fuel goes.
Much easier to do this way as well, though can be undone first if needed.
There's a smaller 1/2" approx pipe running from filler neck to tank, if removing the float assembly use a new gasket, there are two different ones listed, it is the smaller of the two that is needed, but they're cheap enough.
steerfromdarear
28
29-01-2016 06:14 PM
ekjim
17-08-2015 08:57 PM
