Base idle..
Old Mar 9, 2004 | 02:16 PM
Default Base idle..
Hello
What is the correct way in setting the base idle on a 4x4 cossie?
I have found mine to be hunting slightly.
Graham.
Old Mar 9, 2004 | 03:24 PM
Guinnless's Avatar
Guinnless
Disconnect ISCV. Adjust bleed screw buried under the throttle body.
Set to 850-900 rpm.
Old Mar 9, 2004 | 03:34 PM
Panza's Avatar
Panza
Old Mar 9, 2004 | 04:40 PM
HI,
After your base idle is set as above, put iscv plug back on may rise up a bit first
this is normal, and will function as normal afterwards.
Dave
Old Mar 9, 2004 | 05:04 PM
PJay's Avatar
PJay
Also the idle speed it so be set with the fans running at so may sit slightly high on an everyday basis but should never really be above 1000rpm when warm
Old Mar 9, 2004 | 05:12 PM
HI,
Set base idle without FANS on as when iscv is connected any load ie elctrical
fans , headlight, etc ECU corrects idle, this is what its for, some cars are set with
fans on ie erst, but they dont have idle speed control valves,
Dave,
Old Mar 9, 2004 | 06:48 PM
Hi,
Just hope your base idle control screw is'nt seized like mine was!!
Fitted second hand throt body and set idle,drives like a diffrent car now.
Was up and down before whenever you pulled up.Good luck!!
Old Mar 9, 2004 | 07:44 PM
PJay's Avatar
PJay
Originally Posted by davidreader5
HI,
Dave,
Was thinking RST
Old Mar 10, 2004 | 07:13 AM
Thanks guys for the replies.
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
SMILER258
Sep 28, 2015 09:04 AM
IainRS1700T
Sep 25, 2015 06:44 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
