Whats the difference in red oxide and Etch primer
Old Dec 12, 2009 | 04:13 PM
cossie legend's Avatar
cossie legend
Default Whats the difference in red oxide and Etch primer
Whats the difference in red oxide and etch primer and what situation would you use one over the other?
Old Dec 12, 2009 | 08:31 PM
cabriolet's Avatar
cabriolet
etch primer contains a acid that eats into the metal red oxide is a surface covering [sealing] paint the old lead based one [now banned] was the bollocks red oxide is the old school way of doing things etch primer the new way this ones down to personal preferance fella
Old Feb 18, 2010 | 04:42 AM
M K's Avatar
M K
bringing this post back to the top,
when i bring my shell back from AG MOTORSPORT, what is the best protective paint i can put on it?
im gonna get it painted soon as i can but at the minute its bare sheet steel/metal most of it and im gonna have it open to the elements to some extent for an 8 hour drive on the way home,
will these surface rust bits need a clean up before painting with something tempararily?
thanks Marc
Old Feb 18, 2010 | 07:49 PM
Toe Knee's Avatar
Toe Knee
yea mate any loose rust etc will need taking off first or the paint wont stick to it. If ur doing alot of metal and have access to a compressor and dont mind spraying it urself buy a tin of etch primer rather than a can and spray all the bare metal surfaces with 1-2 coats, then your best bet again is some 2k primer again spray out of a gun if u can. You can obviously use cans instead but for the amount of bare metal it looks like u have in the pics you'd go thru shit loads
wowk
Mar 30, 2021 07:49 PM
Nov 1, 2015 06:53 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
