engine swap
Old Nov 29, 2009 | 06:08 PM
orionadam's Avatar
orionadam
orion
Default engine swap
hi guys ive got a 1.6 zetec engine out of an s reg escort to go in my mk2 ohv orion, the new engine comes with an alarm and immoblizer, ive got the ecu and the black ring, do i need the barrel and key aswell or is there a way to by pass the immoblizer, also i can have anythin i need from the engine bay of the escort, what else do i need to make it fit and run in my orion. cheers in advance guys
Old Nov 29, 2009 | 10:44 PM
orionadam's Avatar
orionadam
orion
anyone plz
Old Nov 30, 2009 | 08:45 AM
bernie0121's Avatar
bernie0121
you need the key as its got the transponder in it for immoberiler
Old Nov 30, 2009 | 10:23 AM
orionadam's Avatar
orionadam
orion
ok but do i need the ignition barrel, also will the zetec gearbox fit in my orion
Old Nov 30, 2009 | 03:51 PM
orionadam's Avatar
orionadam
orion
any plz, some help wud be great
Old Nov 30, 2009 | 04:26 PM
mk4gartrac's Avatar
mk4gartrac
I wouldnt bother with the 1.6 zetec the bigger zetecs are much better or even the cvh
Old Nov 30, 2009 | 04:43 PM
jammerrs's Avatar
jammerrs
standard gearbox will be fine i beleive (95% sure)
Old Nov 30, 2009 | 05:01 PM
orionadam's Avatar
orionadam
orion
yes i no what u are sayin but i need an engine asap and these is a very good engine at a cheap price, does anyone no what else i need also do i need the ignition barrel for the imbolizer
Old Nov 30, 2009 | 06:22 PM
bernie0121's Avatar
bernie0121
you can change the barrel as you need the key gear box should fit just make sure mounts are same and drive shafts cluch should be cable same as yours will my also need front half of wiring loom hope this helps
Old Nov 30, 2009 | 10:34 PM
orionadam's Avatar
orionadam
orion
cheers mate ive gt the hole engine loom
JoeyBoyden
Jan 4, 2024 02:36 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
track.focus'd
Aug 12, 2015 05:53 PM
vdubo7
Aug 2, 2015 08:17 PM
