esc rst - alternator prob - help!! :(
Old Nov 28, 2009 | 12:34 PM
cosworth_wannabee's Avatar
cosworth_wannabee
Default esc rst - alternator prob - help!! :(
hi all, i have just got a new alternator off the net as my old 1 was giving up on me. Its shaped exactly the same so it will fit, the only thing is the electrical side of things is a bit different. ive put a pic of the 2 below to show what i mean. the original i just took off just had 2 wires on the alternator. the new 1 has 2 parts where wires are too be fitted too, as shown in the pic circled in green, but i am worried about the spade connections found which i have circled in red, am i missing something or are these nothing to worry about and should i wire it up as the old 1 was?!?!
the old alternator says b+ and d+ for the wires and the new 1 says W and B.
any help on wiring this would be great cheers.
Old Nov 28, 2009 | 01:08 PM
iansoutham's Avatar
iansoutham
OCD Victim
I assume that your RS has a heated windscreen as the old alternator is a 70A one.
The two spade terminals on the alternator on the right are generally only used with 55A or lower alternators. The other connections are probably for different types of car with bolt-on terminals as standard.
The W output is a single-phase output normally used for things like Diesel revcounters.
The D+ output would be the blue wire for the battery light on the dash
The B+ output would be the big red wire from the battery/starter motor.
I would say you have a 55A alternator supplied, not a 70A one. Check the label on the side of the alternator to confirm.
Old Nov 28, 2009 | 01:19 PM
cosworth_wannabee
hi, its a 75 amp alternator, well so the seller tells me.
so shall i just wire it up as it has been already and not worry about the spade connections?? cheers
Old Nov 28, 2009 | 01:42 PM
mk4gartrac's Avatar
mk4gartrac
I was running a big ice system on an old mk4 rst and killed the alternator so was advised to put a 90amp one from a granada v6 with full electric pack the only differance is the puly is a bit bigger but it went straight on and never had problem again
iansoutham's Avatar
iansoutham
OCD Victim
As long as you wire it up as above, i.e. B+ to battery, D+ to blue wire and leave the W alone, it should work fine.
Once running, I would get the available output checked though as I am still suspicious.
Old Nov 28, 2009 | 02:43 PM
cosworth_wannabee
ok kool, but on the new 1 there is no d+ only b+ and a w, so should i put the d+ to the w???
Old Nov 28, 2009 | 04:53 PM
On the NEW alternator the smaller spade terminal, in the same slot as the two larger ones, is for the warning light, so this would be where the D+ needs to be wired to.
Old Nov 28, 2009 | 04:56 PM
cosworth_wannabee
ok thank you very much. so i havent got to worry about any of the other connections. jus the d+ to smaller spade and larger wire to b+. thanks all
Old Nov 29, 2009 | 12:07 PM
Yes, that's all you need, as you've said.
Old Nov 29, 2009 | 05:37 PM
JesseT's Avatar
JesseT
Yes, teh two larger spade connector are both B+ and should both be connected as one cannot carry the amperes alone.
A.t.p
Oct 23, 2015 07:54 PM
gcfcos
59
Oct 6, 2015 05:04 PM
A.t.p
Sep 29, 2015 05:04 PM
Billy_RS
Sep 13, 2015 04:17 PM
