resistor
Old Nov 21, 2009 | 08:34 PM
martin murrell's Avatar
martin murrell
Default resistor
Can anyone help. I'm fitting a Stack unit to my cosworth and i have to fit a 47K ohm resistor to the coil. Can anyone tell me where i can get one from
Old Nov 21, 2009 | 08:36 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
try RS components mate
Old Nov 21, 2009 | 08:40 PM
martin murrell
Had a look on their web site and book, but nothing at 12v
Old Nov 21, 2009 | 08:57 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Look for Wattage rating not Volts.
W= V x A
Old Nov 22, 2009 | 12:15 PM
As ROD says you need to know the wattage, the resistor is the easy part, but get one too weak, wattage wise and it will burn out.
When you know the wattage look for CERAMIC resistors, if you get stuck pm me with the details, they're a only a few Ł's, so no biggee.
They may well be rated at 500V or more but this is as said irrelevant.
Old Nov 22, 2009 | 05:39 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i'd look at maplins fella, have loads of items in stock.
Old Nov 22, 2009 | 07:26 PM
martin murrell
Thanks for the info guys. The Stack unit has to be connected the negative terminal of the coil for engine speed. I've had a look through the Stack manual and it doesn't tell me any tech as to what the amp is. I thought that the resistor had to be D.C. voltage and not A.C. mains
Old Nov 23, 2009 | 12:24 PM
Resistors don't care what the type is ac or dc, obviously with ac they need to be half the resistance as they only have half the live, ie one negative wave and one positive, they only need to resist the positive.
What exactly does the manual say, if it's connected the the LT side of the coil negative why does it need a resistor externally mounted ?
PM me the exact ecu model and I'll check with me wiring man as he's bound to have done looms for these before.
Old Nov 23, 2009 | 09:30 PM
martin murrell
Hi, the Stack model is ST8130. When connecting to a Ford a 47k ohm resistor is required. It just says ' For system which require series resistor on the engine speed wire the resistor must be connected directly to the negative terminal to limit interference from the high tension leads.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
beller
Sep 21, 2015 04:13 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
hydro st170
Ford Focus ST
Aug 28, 2015 01:26 PM
Martin-Hadland
90
Oct 26, 2008 09:17 AM
