difference between an cossie 2wd & 4x4 head
Old Nov 20, 2009 | 09:11 PM
cossie15's Avatar
cossie15
Default difference between an cossie 2wd & 4x4 head
can anyone tell me the difference between an cossie 2wd & 4x4 head? been told ive got an 4x4 head but not sure!
Old Nov 20, 2009 | 09:14 PM
louie1's Avatar
louie1
turbo oil feed is between cylinders 2 and 3 on a 4wd
Old Nov 20, 2009 | 09:43 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
The 4x4 head does not have a cast block over the exhaust side for the turbo damper.
Steve
Old Nov 21, 2009 | 11:33 AM
As above and the 4wd head has 3 bolts for thermostat housing, it also has different shape holes for the water, in that it has holes as opposed to long slits of the 2wd, in essence it is superior.
Old Nov 22, 2009 | 07:54 PM
louie1's Avatar
louie1
hi tabetha, from memory i think you will find that only early 2wd heads(3 door) had two bolt holes for the thermostat and the later 2wd(saph) had three.
I will need to check some heads in my workshop to confrim this though.
Old Nov 23, 2009 | 12:20 PM
Just going by my car, which is a 88 sapph, which defo has two holes.
Old Nov 23, 2009 | 01:46 PM
cozmeister's Avatar
cozmeister
More boost Igor!
ie, a 4x4 head is not made of chocolate.
Old Nov 23, 2009 | 02:22 PM
cossie15's Avatar
cossie15
well it seems i have a 2wd head, the thermostat housing has 2 bolts. The b--ted lied to me!!!!!!!!!
Old Nov 23, 2009 | 05:06 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Check the part number on the front - that's more definitive.
2wd (86 - 89/90): V86 HF 6090 AA
4x4 (90 - 92): V89 HF 6090 AAh
Old Nov 23, 2009 | 06:07 PM
All 4wd have 3 holes, the rejigged thermostat housing was one of the improvements made, for faster warm up times(heater).
Old Nov 23, 2009 | 11:57 PM
cossieDavedree's Avatar
cossieDavedree
2wd late spec heads look like this on the water jackets, and have 3 holes for thermostat
Old Nov 24, 2009 | 12:46 PM
Something else I've learnt.
Old Nov 24, 2009 | 01:15 PM
cossie15's Avatar
cossie15
Well im amazed! so only by taking it apart i can tell, right???
By the way cossieDavedree that engine looking sweat man!!!!!
Who done the engine work for yah?!!
Old Nov 24, 2009 | 07:10 PM
louie1's Avatar
louie1
Thats saved me going up my workshop to take pictures cheers!!!
Old Nov 24, 2009 | 09:57 PM
cossieDavedree
thanks I did all the work myself, bar the cam cover, which was already done when i bought the car.
As people have said on here,, You can check the part number on the front of the head,
3 bolt thermostat and turbo damper lugs not present would more likely be a 4x4 head.
Theres also a difference in combustion chamber volume between a 4x4 head and 2wd.
Good luck fella.
Old Nov 25, 2009 | 12:30 PM
SumpNut's Avatar
SumpNut
This is interesting, my 1989 2wd saphire has three bolts for the thermostat housing, but has the older style wide slits for the waterway rather than the three holes in the head below.
FlashRS
Sep 14, 2015 12:36 PM
turbotrev
Aug 22, 2015 11:41 AM
MARKYMARKONE
Aug 20, 2015 12:55 PM
RsS2daz
Aug 14, 2015 05:26 AM
Old ford
Jul 31, 2015 06:50 AM
