pinto block
Old Nov 17, 2009 | 01:41 PM
rs tingle's Avatar
rs tingle
Default pinto block
hi i was just wondering if a pinto block could be used as a cosworth block a 2.0 block i found one that has 2222 by the dizzy i now the cosworth block were jus selected pinto block would that mean i could use a std pinto or is it a no no
Old Nov 17, 2009 | 01:55 PM
CombatSapph's Avatar
CombatSapph
There's no difference. Non 4x4 Cosworth blocks were simply cherry picked Pinto 205 blocks that had excellent tollerances - which yours has denoted by the 2222 gradings. Your block could as easily ended up in a Cosworth.
Once you rebore them though the bore gradings are meaningless.
Old Nov 17, 2009 | 02:15 PM
rs tingle's Avatar
rs tingle
so what would need to be done to the block to use it as a cosworth block .do ya think gettin it xrayed would be gud
Old Nov 17, 2009 | 03:47 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I used a normal 205 pinto block running upto 340bhp for 7 years before it broke.
Steve
Old Nov 17, 2009 | 05:17 PM
rs tingle's Avatar
rs tingle
right im havein the block out this old transit there scrapping at work then lol thats got the 2222 on
Old Nov 17, 2009 | 08:38 PM
rs tingle's Avatar
rs tingle
iv jus read that the early transit pinto arnt the same as the cosworth block is this correct lol
Old Nov 17, 2009 | 09:26 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
All i know is that a transit pinto had a lower comp than a normal pinto.
BTW my block did have a cossie crank and rods fitted in it.
Steve
Old Nov 17, 2009 | 10:07 PM
martysmartie's Avatar
martysmartie
Then it would be designated 20 not 205 in which case you can't. If it is 205 (revised in 1985-1990 hence where the 5 on the end comes from) then as said it's just a selected 205 block and you can use it.
Martin
Old Nov 17, 2009 | 10:17 PM
rs tingle's Avatar
rs tingle
dam i thought i was onto a winner then oh well lol
chowfornow
14
Jan 5, 2019 09:01 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
AJC
Oct 1, 2015 06:47 PM
20/20 vision
Sep 29, 2015 11:27 AM
