replacement engine, will my chipped ECU be ok to run it??
Focus WRC
hey guys, im having a replacement engine fitted to my rst and am wondering if my chipped ecu will be ok running it?
my last engine was the same besides kent cams,ap clutch and vernier pulleys. Obviously i know every engine is different so the maps/fueling is slightly different but i want to know if my old setup chip should be ok running the replacement engine for a bit until i have it set up properly by MSD?
Thanks
Thanks
Focus WRC
its not running it in, the new engine already has 14k miles on the clock so has been ran in and previous setup. im asking if it would be ok for the chip to run the engine?
big_Rad
15-09-2017 09:36 AM
kosienutter
31
22-08-2015 09:55 AM
ekjim
17-08-2015 08:57 PM
