Front strut removal.
Old Nov 11, 2009 | 03:25 PM
Mitch01roo's Avatar
Mitch01roo
ZVH sold =(
Default Front strut removal.
I have undone the top mounting and big 19mm from the bottom but I can't get the bottom part to slide off no matter how hard i hit it? Has anyone here got any advice me? Thanks Mitch.
Old Nov 11, 2009 | 03:26 PM
JEEMO's Avatar
JEEMO
You mean you can't get the carrier off? Try spraying WD40 on it and leaving it to soak then try and get it off.
Old Nov 11, 2009 | 03:56 PM
m4tt274's Avatar
m4tt274
what car is it and what else have u taken off?
does it look like this
DSC00269.jpg?t=1257958335
if so. do the top mount back up and then use a wooden chock or similar on the carrier and then carefull of paintwork bash it with a hammer and it should slowly slide off. if its really stuck soak it in wd40 or diesel.
then it should look like this just with TCA's etc still in place etc.
DSC00271.jpg?t=1257958527
ther the only pictures i have of this sorta thing but it shows sorta what i mean
Old Nov 11, 2009 | 04:01 PM
Mitch01roo's Avatar
Mitch01roo
ZVH sold =(
Awesome guys, thanks for the replies. I will soak it in WD40 and leave it over night, hopefully this will free it up. I'm only removing them as the guy I bought it off fitted the springs upside down in the koni adjustables!!! Got the car yesterday and i'm going over it with a fine toothed comb, hence all the questions.
Old Nov 11, 2009 | 04:10 PM
JEEMO's Avatar
JEEMO
Ah i see, that should hopefully work. had to do the same on my Fiesta as it had been sitting for a while before I fitted my coilovers, good luck.
Old Nov 12, 2009 | 08:49 AM
WD40 won't help here, get a thick washer, or thin bit of flat metal.
Now after removing the clamp bolt holding the strut to the hub, put the bolt back in from the opposite side, it the THREADED side instead of the hole, now with the bit of metal/washer insert in the slit of the hub, so that as the bolt is wound in it hits the metal/washer, now when turning this bolt it opens up the slit and the hub will literally fall off.
Don't open as far as you can, just enough so it knocks off ok.
Yes you can use a chisel to widen the slit, but this is safer, and doesn't run the risk of hurting yourself if you miss with the hammer
Old Nov 12, 2009 | 09:38 AM
Mitch01roo's Avatar
Mitch01roo
ZVH sold =(
Thanks for that, sounds like the best way of doing it! thanks. Mitch
Old Nov 12, 2009 | 10:27 PM
m4tt274's Avatar
m4tt274
thats bloody clever. wish i had thought of that haha
Old Nov 12, 2009 | 10:57 PM
Mitch01roo's Avatar
Mitch01roo
ZVH sold =(
I tried do to it but I couldn't get a washer in the gap even when trying to prise it open with a flat head screwdriver. In the end I got my blowtorch out and beat it with a hammer. Got there eventually! One more tick off my huuuge list of repairs.
Old Nov 15, 2009 | 11:45 AM
m4tt274's Avatar
m4tt274
any pics of the car?
rex647
Mar 6, 2022 06:20 AM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
cossirob
Sep 3, 2015 09:17 PM
