patch leads for 97 escort
Old Nov 7, 2009 | 09:55 AM
ruthyduthy's Avatar
ruthyduthy
Default patch leads for 97 escort
somethings draining power from battery but altenator must be ok cos car run fine for 2 wks with new battery. i know the electrics play up at times and have been advised to try patch leads straight from alternator to battery. how do i do this and will it work?
Old Nov 7, 2009 | 11:09 AM
martysmartie's Avatar
martysmartie
The charging system can not be ok if the batterys been drained in two weeks, how often is the car in use? Have you checked to see if the battery is charging?
Martin
Old Nov 7, 2009 | 11:30 AM
Alternators can drain battery power, when faulty and then correct themselves till they feel like it again.
Just because it's new and or charging perfectly does NOT rule it out, a simple test is put a bulb between a battery lead and the battery post and see if it glows as this tells you current is flowing through it, then disconnect the charge wire from the alternator marked B or B+, the see if glowing stops.
JK12
33
Apr 26, 2021 12:09 PM
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
15
Oct 7, 2015 03:43 PM
stevierob
Sep 7, 2015 07:09 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
