fezza turbs pinking
Old Nov 4, 2009 | 11:52 PM
fezzaturbs's Avatar
fezzaturbs
Exclamation fezza turbs pinking
hi, am new ta this so bare wit me i got a 1990 fezza rst wit sum mods 195 bluchip, beige injectors, t3 turb, pace twin capacity alloy intercooler, amal valve n a -31 actuator. i think she's boostin 1.2 bar but ive noticed a slight pinking noise in 3, 4 n 5th gear, high rev n full boost. before i fitted the -31, she was runnin 0.4 bar n never pinked but u could feel her slightly kangaroo at 132mph like she wanted more fuel. fitted the -31 n amal valve and now she's boostin, she's pinkin. also in the mornings, if you back of the throttle, she pops n farts like a good en, which every rs ive heard do, but after 10 mins, u back off n shell sound flat. obviously she's efi so it has no choke so am i right in thinkin that them first 10 mins is wen the ecu is runnin more fuel to componsate choke, hence why she goes flat wen shes warmed up n the fake choke has switched itself of?? to me its all pointin to not enough fuel coz im still runnin standard fuel pump, hence the flatness wen i let off throttle n pinking at high revs n boost. would a uprated fuel pump sort her out???? many thanks
Old Nov 5, 2009 | 12:00 AM
Robs Frst's Avatar
Robs Frst
Get a escort cossie fuel pump asap, get her set up.
Old Nov 5, 2009 | 12:06 AM
fezzaturbs's Avatar
fezzaturbs
thanks dude, cant quite rememba the make ( walbu or summat) but been lookin at pumps n i found 1 good 4 255 lph???? will that do? 80 quid brand new
Old Nov 5, 2009 | 03:17 PM
I'm not overly familiar with the festa's but think they are external pump ?, if so a std cossie 941 pump will be fine, but if wanted a 044 pump can be fitted instead, both easily capable of your power.
Old Nov 5, 2009 | 08:28 PM
fezzaturbs's Avatar
fezzaturbs
thanks m8. ive just bought a warlbu upgraded pump capable for 400 bhp so thats plenty lol n the fiesta pump, goin by the look of new pump is inside the tank. thanks
Old Nov 5, 2009 | 08:37 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
internal pumps on the mk3 fiestas
Old Nov 5, 2009 | 08:49 PM
fezzaturbs's Avatar
fezzaturbs
thanks dude. do u no if the mk3 fezzas have a knock sensor?
Bailes1992
Sep 3, 2015 02:17 PM
Bailes1992
Aug 16, 2015 07:14 PM
JaysS2TURBS
Jan 8, 2005 04:25 PM
JaysS2TURBS
Jul 13, 2004 04:43 PM
