Boost explanation
Old Nov 4, 2009 | 05:36 PM
2wdsaff's Avatar
2wdsaff
Default Boost explanation
Ok without sounding totally stupid here but can somebody explain to me simply and shortly how the boost control etc works on a 2wd cosworth....
such as whats bleed and i get that boost pressure isnt controlled just by the actuator..... please
Old Nov 4, 2009 | 07:27 PM
crazyshad1's Avatar
crazyshad1
i do know that if you screw the actuator in (shorten the rod) then that increases boost. not 100% sure how bleed valves work. not sure that answers your question, sorry
Old Nov 4, 2009 | 07:30 PM
benjaminsarmy's Avatar
benjaminsarmy
escort rst cosworth rep
hi mate dont know much but my t3 wont boost it is only run by vacume due to boost issues id like to know too ive been told its air and fuel mix to high best advise is ask your local rolling road or keep trying on here some one will deffly help mate
Old Nov 4, 2009 | 09:38 PM
2wdsaff's Avatar
2wdsaff
i know how the actuator etc works and get the adjusting etc, i just dont understand how you can get say 1.5bar when your actuator is set to 1 bar and your "bleeding" 0.5bar?????
how does the bleeding etc work?
Old Nov 4, 2009 | 09:49 PM
RS1HEN's Avatar
RS1HEN
its bled out of the turbo wastegate by the actuator, into the exhaust
Old Nov 4, 2009 | 09:59 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
ok ill give it a go
the exaust gases exit the engine and are directed vire the exaust manifolt down to the turbine half of the turbo this in tern rotates the turbo shaft up to any think in excess of 150000 rpm
on the other end of the shaft is the compresser housing this then drags air (through a filter/ meatering head air flow meater ect ect ect) in the inlet compressing it and feeding it through an intercooler (due to the fact the turbo is bolted to the exaust manifold it has a tendancy to get hot hence the need for an inter cooler) then it makes its way to the inlet side of the engine
when the disired boost leavle has been reached the positive boost presure will act on the actuator (dependant on the type and how its set up ect) and will open the wastgate within the turbo exaust housing bypassing the exaust gases around the the turbine half of the turbo and directley into the exaust system to stop the turbo from spooling any more.
now talking about the "bleed valve" when the actuator starts to move opening the wastgate say its set to 10 psi for arguments sake the bleed valve will bleed some of the presure out of the feed pipe going to the actuatur so the turbo will have to work harded to get the actuator to move (hence now the boost presure has been increased)
and that i hape ancers it lol sooooooooooo sorry for my spelling lol
Old Nov 4, 2009 | 10:04 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
The cosworth boost control is quite simple,
ok, in laymans terms going right back to basics,
the turbocharger produces boost pressure, produced by the exhaust gasses driving the turbine wheel which in turn drives the compressor wheel,
now to slow boost down we need to prevent so much exhaust gas passing over the turbine, so we open the wastegate which bypasses the turbine, so it slows down, thus producing less boost pressure.
boost control simply has to control the operation of the wastegate itself, which will control turbo speed or boost pressure...
to do this we use a wastegate actuator which is pressure operated, ie at 1 bar it will open the gate and slow the turbo,
so if we want to run 2 bar of boost, we need to stop 1 bar of the boost pressure reaching the actuator, otherwise it will open at 1 bar! so we bleed some off through the amal valve. this valve is ecu controlled and can be opened and closed at different points in the map,
theres much more to itbut thats about as simple as i can make it this late lol
edit, i see i was beaten to it lol
LHD220Turbo's Avatar
LHD220Turbo
assuming you know how wastegates/actuators work?
in simple terms a bleed valve works by bleeding/diverting air away from the wastegate - therefore it "tricks" the wastegate into thinking the actual boost presure is lower.
bleed valves are OK if used in the correct manor; but people get too boost greedy and turn the bleed valve too much which then causes lean running = bang goes engine
Old Nov 4, 2009 | 10:08 PM
LHD220Turbo
beaten to it; my explanation was pants compared to Clarke & James
Old Nov 4, 2009 | 10:16 PM
LHD220Turbo
here's a good picture which shows both sides of the turbo; wastegate and actuator
Old Nov 4, 2009 | 10:19 PM
clarke5700's Avatar
clarke5700
james spelling was better tho lol
Old Nov 4, 2009 | 10:23 PM
LHD220Turbo
he was obviously paying attention in English lessons!
Old Nov 4, 2009 | 10:24 PM
JTECH James
Passion for Fords!
no, i just took longer typing, hence i came in second pmsl
i`ll let you guys tackle air injectors, ,im off to bed
Old Nov 4, 2009 | 10:28 PM
clarke5700's Avatar
clarke5700
Old Nov 4, 2009 | 10:33 PM
LHD220Turbo
leave air injectors up to you James tomorrow!!
my simple understanding is they work in the opposite way; by bleeding air in. Only normally seen in big HP cars due to being more accurate! - i hope that's slighty right! lol
Old Nov 4, 2009 | 10:36 PM
JTECH James
Passion for Fords!
yeah thats the idea
Old Nov 5, 2009 | 10:38 AM
2wdsaff's Avatar
2wdsaff
lol at the posts! thats perfect, explained it down to a tee!!! thank you very much
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
