rev counter issues
Old Oct 26, 2009 | 06:07 PM
djchurch2001's Avatar
djchurch2001
Default rev counter issues
Right got a problem my rev counter is giving me the wrong reading. When i rev the car it should be around the 2 grand mark but the gauge is saying 5. What could be causing this?
Old Oct 27, 2009 | 06:31 PM
Has it just started doing this ?, or is it after some ignition changes ?
Either way the tacho is only a re scaled volt meter, so might have gone duff as they do often.
Old Oct 27, 2009 | 06:53 PM
djchurch2001
i have just done a turbo conversion so a new loom has gone in, the counter was working fine before i chaged the engine but the counter from the donner car worked fine. Just slight tap of the pedal is reading a massive increase in revs
Old Oct 27, 2009 | 08:55 PM
martysmartie's Avatar
martysmartie
Have you changed from a coil to a coil pack if so the old tacho will not work.
Martin
Old Oct 28, 2009 | 02:00 PM
SO did you do any ignition changes ?, ie the ever popular coilpack from std coil ?
Old Oct 29, 2009 | 09:28 PM
djchurch2001
The car was running 3i management with coil pack now it's running rs turbo mfi management with Std coil. The only thing I have not changed is the dials will are still 3i.
Old Oct 30, 2009 | 09:14 AM
That's your problem, the different ignition system, you need a rev counter for the type of ignition system, you can go from coilpack to std coil or vice versa without changing /modding tacho.
Mark_
14
Jan 16, 2016 05:27 PM
SMILER258
Sep 28, 2015 09:04 AM
turbotrev
14
Sep 27, 2015 10:44 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
pabloXR
Sep 21, 2015 12:42 PM
