CVH oversize main bearings????
Old Oct 24, 2009 | 08:40 PM
GINGExR2 T's Avatar
GINGExR2 T
Default CVH oversize main bearings????
I've just had a FRST crank recon'd for a rebuild and needed .25mm o/s regrind and bearings. After getting it back i notice what looked like a crack in one of the bores of the block, so managed to get hold of another block from a Mk3 Fiesta 1600sport, Now i've striped the block drilled the oil return etc, after fitting the new mains into the block i noticed some thing wrong with the way they sat. After looking at the original mains that came out of the 1.6s block they where stamped STD (standard), but also has 0.4mm O/S. Ford used to list oversize and undersize bearing, I now need different mains, 0.25mm O/S but with a 0.4mm undersize fitment, this is the 1st 1600 CVH block i've ever seen like this,does anyone know if these are avalible???
Ginger
Old Oct 25, 2009 | 10:47 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
they must be availible, but i'd measure the thickness of the crank on the mains and measure the inner diameter of the bearing when bolted together, then you can find out the thickness of the shell that you need.
Old Oct 25, 2009 | 08:59 PM
Ring 01359 251888, ask for Brian, he'll soon sort the problem of shells for you.
Old Feb 8, 2010 | 12:32 PM
gazm's Avatar
gazm
just doing my block and found my mains are 0.4 o/s from ford stamped ford /vandervell. anywhere I can get these....
Old Feb 8, 2010 | 03:55 PM
the number above you.
Old Feb 8, 2010 | 04:07 PM
tooly80's Avatar
tooly80
tooly80
i had to get mine that size from specialist engines, because the size was obsolete for my crank.
Old Mar 4, 2010 | 09:52 PM
gazm's Avatar
gazm
tried the number - spoke to Brian - but alas no joy - these are rarer than hens teeth so still on the look out.........
Old Mar 26, 2010 | 06:20 PM
javierant3's Avatar
javierant3
Hello, I`m rebuilding my engine and found that I have the rare +04mm housing. It`s a possibility to get these bearings?
Old Mar 27, 2010 | 03:11 PM
tooly80's Avatar
tooly80
tooly80
give these a ring mate they helped me 01375378606.
Old Mar 27, 2010 | 09:04 PM
javierant3's Avatar
javierant3
Thank you very much for the responses but in the end I got an EFI engine in the scrapyard with standard bearings and will use this block.
89barto89
Oct 4, 2015 06:59 PM
fordrallycar
Sep 30, 2015 07:57 PM
20/20 vision
Sep 28, 2015 03:03 PM
