Turbo vacum help
Old Sep 19, 2009 | 07:06 PM
djchurch2001's Avatar
djchurch2001
Default Turbo vacum help
There is a nipple on the side od the turbo housing that i dont know where i have to conect it to.
Also the nipple on the acctuator, can anyone help.
Old Sep 19, 2009 | 08:15 PM
They are connected to each other, through a boost control valve normally.
Old Sep 19, 2009 | 08:19 PM
djchurch2001
great thank, there are 2 nipples on the amal; valve where do they go?
Old Sep 20, 2009 | 10:50 AM
If you look REALLY carefully you will see they have a letter or a number by each pipe.
1 = Actuator, could also be A
2 = Compressor Housing could also be H, this is the nipple you refered to earlier.
It doesn't matter too much either though as it is only a straight open shut valve.
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
