oil filter HELP PLEASE
Old Sep 19, 2009 | 02:25 PM
griffo69's Avatar
griffo69
Default oil filter HELP PLEASE
afternoon all this may be a silly question but how would i get a stuck oil filter off on an rs turbo. ive got a chain link wrench which does nothin also tried the screwdriver trick but that just made the hole bigger so now im left with a mashed oil filter to get off please help
Old Sep 19, 2009 | 02:55 PM
ste45's Avatar
ste45
have you hammered the screw driver so that it comes out the other side then turn ? this always worked for me until i got the proper chain wrench tool
Old Sep 19, 2009 | 05:57 PM
Jesus it must be tight for a chain wrench not to move it, I assume it was just crushing inwards ?
Try a jubilee clip as close to the engine end as you can as more strength there, tighten really well and tap around with a long bar and hammer, the shocking action from the hammer helps as well.
Old Sep 19, 2009 | 07:57 PM
fonfe123's Avatar
fonfe123
small chisel on the rim of the filter if tabetha's way wont shift it, be very carefull but ive done it that way when all else failed before.
Old Sep 19, 2009 | 08:07 PM
griffo69's Avatar
griffo69
thanks for your help peeps, used the wrench it buckled the shit out of it but managed to loosen it so i got it off but when i changed filter and put new oil in i started it engine sounds quiet apart from a faint tapping/rattling sound coming from the engine. theres no smoke and i have good oil pressure any ideas what it is
thanks again
Old Sep 19, 2009 | 08:48 PM
griffo69's Avatar
griffo69
bump !!! any ideas lol
Old Sep 20, 2009 | 10:44 AM
Most likely just the tappets, will no doubt be better after a run.
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
