rs turbo wont start
Old Dec 20, 2004 | 08:24 PM
creedy's Avatar
creedy
Default rs turbo wont start
arhh help me plz!!!
it hasnt been started for about 2 months caus iv had the head off to do the head gasket, there was a wire going to the fuel pump relay broken but i have fixed this. the fuel pump works sometimes and other times it doesnt, but the car wont start at all. any1 help me??
Old Dec 20, 2004 | 08:40 PM
radiant red's Avatar
radiant red
you need to make sure yhat you have correct fuel pressure as the k/ke jet system requires around 6.1 bar to function correctly. Make sure you havent missed anything out, are you 100% your cam timing is correct? ignition timing?do you have a good spark?
Old Dec 21, 2004 | 04:15 PM
creedy's Avatar
creedy
the fuel pump is pumping as i took the pipe of be4 the filter and was coming out there. also the fuel isnt coming out of the metering head when i took the bolts out. i think the
distributor isnt lined up right as i didnt mark it up correcty how do i go about checking this, and also adjusting it?
Old Dec 21, 2004 | 04:39 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
I know this may sound silly, but have you changed the Fuel Filter??
Old Dec 21, 2004 | 04:43 PM
creedy's Avatar
creedy
yeah its brand new, i think its a timing thing realy
Old Dec 21, 2004 | 05:13 PM
creedy's Avatar
creedy
rite there is a spark. is fuel meant to come out of the metering head when u prime pump (not start car)? caus there isnt
Old Dec 21, 2004 | 09:08 PM
radiant red
turn your ignition key several times to build fuel pressure, remove air filter slacken off fuel line to injector and push air flow plate down this will raise the plunger in the metering head and will replicate the effect of air been sucked through. You should then feel the resistance on the plate from the fuel pressure as your pushing it down. This type of sytem is totaly dependant on fuel pressure, you can have good fuel pressure but it may not be enough to open injectors as they only open by fuel pressure there not electronic like most modern systems. They need a fair amount to open. Best to get pressure checked by a good quality gauge
Bailes1992
Aug 16, 2015 07:14 PM
Michael Wisbey
Aug 14, 2015 11:57 PM
rs_turbo_ant
Aug 8, 2015 11:11 AM
Bloody-Fox
Aug 3, 2015 07:48 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
