wiring ppl good with relays - please advise.
Old 23-08-2009 | 11:05 AM
john_p_b's Avatar
john_p_b
Default wiring ppl good with relays - please advise.
right, i'm hoping this makes sense so here goes.
i need to wire 2 relays in, 1 is going to my omex ecu and the other to my fuel pump with a direct 12v feed from the battery. i've got all the wires there now but no idea what pin on the relay i need to put the wires to so can anyone give me any pointers?
i'm using standard ford 4 pin 40 amp relays with the metal clips on, looking at the relay with the metal clip at the top i have numbers going clockwise 30, 87, 85 and 86.
i've "borrowed" a bit of omex wiring diagram and added a bit in myself so you can see what i'm trying to do.
be very gratefull if anyone could help?
Old 23-08-2009 | 11:17 AM
jon@work's Avatar
jon@work
the 86,85 circuit switches the 30,87 circuit
Old 23-08-2009 | 11:35 AM
london_chris's Avatar
london_chris
30 - battery (fused)
85 - -ve (ground)
86 - relay input i.e ecu
87 - relay output, i.e fuel pump
Old 23-08-2009 | 11:48 AM
john_p_b's Avatar
john_p_b
so am i missing something here then as the omex diagram does show a ground on the relay or is that what the blue/white wire is doing?
Old 23-08-2009 | 11:55 AM
london_chris
it would appear the blue/white is the earth, which is switched from the ecu too.
if you power the ecu, test with multimeter to see what the blue/white does
Old 23-08-2009 | 10:29 PM
craig66's Avatar
craig66
Default help please
i have an escort rs turbo have had problems with the fuel pump relay someone please help what are pin 31- for then 15-11 then 1-3 then 54-15 then 30-28 as i want to rewire it as someone has bodged it before i have a permanent live an ignition live fuel pump supply and some more i guess an earth and i think its an ecu signal what do they go to any help will be aprecciated thanks
DixieTheKid
23-07-2023 11:16 AM
markk
02-12-2021 07:59 PM
kosienutter
31
22-08-2015 10:55 AM
