B&m quickshift on a mk2 xr2?
Old Aug 18, 2009 | 12:08 PM
BAZ S1's Avatar
BAZ S1
Default B&m quickshift on a mk2 xr2?
can anyone tel me if the mk3 or mk4 escort B&M quick shift will fit the mk2 xr2 fiesta 88
Old Aug 18, 2009 | 05:35 PM
Shakey Jake's Avatar
Shakey Jake
Try xrtwo.com mate them boys will know.
Old Aug 18, 2009 | 05:43 PM
~nomad~'s Avatar
~nomad~
my mate has one on his mk2 xr2 from a mk3 xr2i, if that helps at all. not sure if escort is same as mk3 fiesta?
Old Aug 18, 2009 | 08:33 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
there isn't much difference between them, the linkage appears to be identical.
i have a mk2 xr2 and i have an erst linkage hung up as a spare and looks identical apart from the mounting plate for the selector.
so would assume the linkage is the same, but the mounting plate would be different as the escort has a wider tunnel.
Old Aug 18, 2009 | 08:46 PM
GTi_Tom's Avatar
GTi_Tom
bolt pattern on the linkages is the same, only difference is the linkage rods, you need the later spec xr2 ones
Old Aug 18, 2009 | 09:28 PM
BAZ S1's Avatar
BAZ S1
so the b&m kit will fit my rods., the b&m kit seems to be the full base and gear leaver will this mate up with my original rods
Old Aug 18, 2009 | 09:31 PM
GTi_Tom's Avatar
GTi_Tom
Yes if it has the later type rods
Old Aug 19, 2009 | 12:33 PM
BAZ S1's Avatar
BAZ S1
yea i got the later type rods just checked
timsrs
Nov 13, 2018 11:48 AM
Kiran1600E
11
Oct 2, 2015 11:35 AM
mondeomark
Sep 28, 2015 06:28 AM
Sp3no
Sep 27, 2015 07:23 PM
